Stripped stud in brake disc - Helicoil or re-tap? | |
One of the cars has fairly new discs but one of the threads in the disc (a Peugeot) for the wheel bolts seems like the thread has been stripped and the bolt only goes hand tight before turning in the hole (have tried another bolt).
The wheel bolt is M12x1.25.
Save having to spend over £100 replacing two perfectly good discs and pads, is it an option to repair the thread with a helicoil/thread insert or to re-tap the hole as M12x1.75 and just get a different wheel bolt for a couple of £ until these discs and pads need replacing? 2015 Range Rover Autobiography 4.4 SDV8
