Home > In Car Electronics (L322) > What is this??
MarkMurphy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
What is this??
Hi all, tring to make sense of the chopped/cut wires in rear, could you please tell me what is this?
Post #646883 30th Oct 2022 4:37pm
whatever you do dont cut the red wire..
(or is it black?)
where is this contraption located? ... - .- -.
Post #646885 30th Oct 2022 5:13pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Looks like a Heath Robinsons attempt to construct a bluetooth / Radio amp?.
I really hope the rest of the wiring is not like that Shocked
Post #646888 30th Oct 2022 5:36pm
MarkMurphy
Thanks for the replies, yes its in the left rear of my l322, where there is wiring hell, had the rangie for just over a week, gradually going through the list, haha
Post #646890 30th Oct 2022 6:14pm
Has it got a non standard head unit, those twisted pairs of wires look like the speaker wires that come out of the original amp, that looks like a basic amp setup maybe...
Does all the ICE in the fatty work..?? Pete
Post #646902 30th Oct 2022 8:06pm
Merchy
Finding that must have been a nasty surprise Shocked If I were you I would make sure you carry a fire extinguisher.
Post #646908 30th Oct 2022 9:16pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Passive crossover for the speakers. Allow connect and split signal to different speakers from single output from amplifier.
made as for a stranger
Post #646911 30th Oct 2022 9:28pm
MarkMurphy
Yes its got a Pioneer android touch screen thing in, it powers up every time i get in, dont know how to use it yet, Haha Very Happy So if its some kind of home brew amp, can i remove it?
Post #646917 30th Oct 2022 10:00pm
Depends if the head unit has a built in amp....
Have a read of this and the other threads mentioned, there is a way to do without an amp and also a way now to keep the original amp...
https://www.fullfatrr.com/forum/topic29219.html Pete
Post #646920 30th Oct 2022 10:40pm
p38arover
Australia
I agree with Jimmie, it looks like a passive crossover for the speakers. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #646930 31st Oct 2022 9:31am
Looks like it's a crossover then, whatever one of them is!!! I know little about ICE, I do know those wires are the speaker wires coming from the original amp, I cut them from the plug and wired them directly to the new head unit that had a built in amplifier.
My original amp, radio etc were drowned in a river in Wales so I had to replace the lot and an Android head unit seemed the way to go...
Good luck with trying to sort it all out...
Speaker wires from when I did it... Thumbs Up
There is a wiring diagram on that thread link for those speaker wires... Thumbs Up Pete
Post #646933 31st Oct 2022 10:04am
mjdronfield
A crossover splits the sound frequencies so the right frequency range goes to each speaker. You don’t really want low frequency bass being sent to a tweeter, or treble being sent to a subwoofer. They can’t produce the sound. The original system used an active system, so the crossovers were in the BM54 amp, and the circuits powered/driven by the 12v feed from the car. This makes the system much more efficient as all the amps power can then be used to drive the speakers. In a more normal passive system the crossovers tend to be on each speaker and the amp has to drive the circuits too, taking quite a bit of its power output and increasing its load.
I know you can just send all the frequencies straight to each speaker but it’s a bit of a waste.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #646937 31st Oct 2022 10:54am
Thanks Mark Thumbs Up Pete
Post #646938 31st Oct 2022 11:01am
MarkMurphy
I get radio noise like when the antenna isn't connected, so i know its connected, i was going to take out the crossover, because its a mess, but if i disconnect it, what would i have to use?
Post #646945 31st Oct 2022 12:00pm
