Home > Technical (L322) > Noise from aux belt goes away when warm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2462 |
There's another recent thread on the topic.
29th Oct 2022 11:06pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 270 |
Yes, from what I read on here this is quite common. The aux belt pulleys and idlers are known to wear and require replacing. Mine were done at just under 70k miles ( approx 10 years). If you’re up for it you can inspect the aux belt to see if it runs fully on all the pulleys. I’m not an expert of this but there’s plenty of discussion on here.
29th Oct 2022 11:08pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Welcome to the squeaky engine club!
30th Oct 2022 7:15am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3173 |
Common issue. At best it’s just belt slip and annoying and embarrassing as people turn their heads to see what the noise is when driving in the morning and at worst it’s a bearing or tensioner about to fail and leave you stranded. Had the whole lot replaced with genuine parts soon after getting mine and it was noisey again after a few months but at least I wasn’t worried it would break. Tried everything from brake cleaner to belt dressing and WD40 but it only lasted until the next startup. Traced the noise / slip to the alternator pulley which is probably the highest load vs smallest surface area so most likley to slip. Replaced belt and tensioner and so far so good. Maybe it was a contaminated belt or maybe the tensioner was just slightly under spec? Also worth trying talcum powder. Key test is to spray some water on the belt while running and if the noise doesn’t go away it’s a bearing so get the whole lot changed as a precaution. 2012 TDV8 Vogue (L322) |
30th Oct 2022 7:19am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
Accessing the belt and pulleys isn't too bad if you have a couple of sockets and a long Breaker bar or torque wrench. Remove the air box and top hoses, and it gives you just enough room to reach everything, including the tensioner. 2015 Range Rover Autobiography 4.4 SDV8 |
30th Oct 2022 7:21am |
It looked far too tight for me so got the garage to do it as they take out the fan and shroud for easier access. If the OP goes this route it's worth checking the water pump and AC compressor are 100% as it's easier to replace these when the fan is out and they are all 'service items' on these engines. 2012 TDV8 Vogue (L322) |
30th Oct 2022 7:39am |
According to the specs that belt dressing contains mineral oil. Do you really want oil on your belt? |
30th Oct 2022 8:43am |
I suspect trying to change my oil without a funnel was the cause of the noise on mine 2012 TDV8 Vogue (L322) |
30th Oct 2022 8:58am |
If it stops the squeal, then maybe!?!? Along with grease on the brakes to stop the squeal there too… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
30th Oct 2022 9:04am |
Not yet; I ordered some but it’s sitting in the garage. I don’t have a major problem. I get what I would describe as a light rubbing sound which is intermittent. Initially I thought it was the fan coming into light contact with the shroud but I can now see that’s unlikely. I suspect it’s a bearing beginning to ware but thought I’d try lubricating as much as I could first. I was fortunate that the belt/pulleys/idlers were replace during the service just before I bought the car (I have the receipt)….. thinking about it I suppose it could be something not properly aligned when refitting but again it seems minor so I’m not concerned. Definitely a bit more investigation to do when I have time. TDV8 4.4 2012 |
30th Oct 2022 9:11am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1203 |
I did all mine a while back and I would only use genuine parts if I were you. I had a pattern tensioner sent to me by mistake and the quality of it was shocking when compared to the genuine part.
30th Oct 2022 9:16am |
It's difficult not to overstate the joy of starting up in the morning without a screeching sound for the first 5-10 mins. I put up with it for nearly a year....... 2012 TDV8 Vogue (L322) |
30th Oct 2022 9:26am |
If I get sufficiently motivated I'll refit my old belt as a test. |
30th Oct 2022 9:55am |
