Home > Technical (L322) > Noise from aux belt goes away when warm
Warkman
Just picked up a 12my v8 4.4.
When c,old there is a squeak coming from aux belt, but goes away when car is warm
Anyone had this?
Post #646821 29th Oct 2022 11:12pm
GraemeS
Australia
There's another recent thread on the topic.
Mines does this after fitting a new genuine belt and pulleys except for 1 non-genuine pulley. As the squeaking ceases when water is dribbled on the belt I'm certain that the noise is from the back of the belt slipping sideways on a smooth pulley at a spot in the belt that jumps sideways a little, possibly at the join in the belt. I consider that the belt is faulty.
Post #646825 30th Oct 2022 12:06am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Yes, from what I read on here this is quite common. The aux belt pulleys and idlers are known to wear and require replacing. Mine were done at just under 70k miles ( approx 10 years). If you’re up for it you can inspect the aux belt to see if it runs fully on all the pulleys. I’m not an expert of this but there’s plenty of discussion on here.
If it’s just a minor squeak you might try spraying on some belt dressing but I found that access is quite tricky.
https://simplybearings.co.uk/shop/p371654/..._info.html
Correction; I checked and it turns out this is what I actually bought
https://www.ebay.co.uk/itm/143052978819?mk...media=COPY
 TDV8 4.4 2012
Post #646826 30th Oct 2022 12:08am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Welcome to the squeaky engine club!
I’m in the same boat as you, however I recently replaced everything and still the squeak returned. Have a look here…
https://www.fullfatrr.com/forum/topic64343.html
In my case I think it’s either belt contamination, or the pulley unit LR022810 as per the post near the bottom of page 1. Unfortunately getting access to prove this, or replace anything is quite involved. I had planned to start this weekend but just didn’t have the mood to tackle it.
I am interested in that spray Rambling Man. Have you tried it? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #646832 30th Oct 2022 8:15am
JayGee
Common issue. At best it’s just belt slip and annoying and embarrassing as people turn their heads to see what the noise is when driving in the morning and at worst it’s a bearing or tensioner about to fail and leave you stranded. Had the whole lot replaced with genuine parts soon after getting mine and it was noisey again after a few months but at least I wasn’t worried it would break. Tried everything from brake cleaner to belt dressing and WD40 but it only lasted until the next startup. Traced the noise / slip to the alternator pulley which is probably the highest load vs smallest surface area so most likley to slip. Replaced belt and tensioner and so far so good. Maybe it was a contaminated belt or maybe the tensioner was just slightly under spec? Also worth trying talcum powder. Key test is to spray some water on the belt while running and if the noise doesn’t go away it’s a bearing so get the whole lot changed as a precaution. 2012 TDV8 Vogue (L322)
Post #646833 30th Oct 2022 8:19am
garyRR
Accessing the belt and pulleys isn't too bad if you have a couple of sockets and a long Breaker bar or torque wrench. Remove the air box and top hoses, and it gives you just enough room to reach everything, including the tensioner. 2015 Range Rover Autobiography 4.4 SDV8
Post #646838 30th Oct 2022 8:21am
JayGee
It looked far too tight for me so got the garage to do it as they take out the fan and shroud for easier access. If the OP goes this route it's worth checking the water pump and AC compressor are 100% as it's easier to replace these when the fan is out and they are all 'service items' on these engines. 2012 TDV8 Vogue (L322)
Post #646840 30th Oct 2022 8:39am
GraemeS
Australia
According to the specs that belt dressing contains mineral oil. Do you really want oil on your belt?
Post #646844 30th Oct 2022 9:43am
JayGee
I suspect trying to change my oil without a funnel was the cause of the noise on mine Embarassed 2012 TDV8 Vogue (L322)
Post #646845 30th Oct 2022 9:58am
Ffrr-lover
If it stops the squeal, then maybe!?!? Along with grease on the brakes to stop the squeal there too… Rolling with laughter Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #646847 30th Oct 2022 10:04am
Ramblin Man
Not yet; I ordered some but it’s sitting in the garage. I don’t have a major problem. I get what I would describe as a light rubbing sound which is intermittent. Initially I thought it was the fan coming into light contact with the shroud but I can now see that’s unlikely. I suspect it’s a bearing beginning to ware but thought I’d try lubricating as much as I could first.
I was fortunate that the belt/pulleys/idlers were replace during the service just before I bought the car (I have the receipt)….. thinking about it I suppose it could be something not properly aligned when refitting but again it seems minor so I’m not concerned.
Definitely a bit more investigation to do when I have time. TDV8 4.4 2012
Post #646849 30th Oct 2022 10:11am
kevinp
I did all mine a while back and I would only use genuine parts if I were you. I had a pattern tensioner sent to me by mistake and the quality of it was shocking when compared to the genuine part.
I also changed LR022810 because it has the fan bearing which I think is also a source of making a noise. I also did the water pump and alternator because they obviously have bearings as well.
Only wanted to go in there once and mine has been lovely and quiet since.
Post #646851 30th Oct 2022 10:16am
JayGee
It's difficult not to overstate the joy of starting up in the morning without a screeching sound for the first 5-10 mins. I put up with it for nearly a year....... 2012 TDV8 Vogue (L322)
Post #646854 30th Oct 2022 10:26am
GraemeS
Australia
If I get sufficiently motivated I'll refit my old belt as a test.
Post #646856 30th Oct 2022 10:55am
