Home > Off Topic - Other Cars > Stripped stud in brake disc - Helicoil or re-tap?
garyRR
One of the cars has fairly new discs but one of the threads in the disc (a Peugeot) for the wheel bolts seems like the thread has been stripped and the bolt only goes hand tight before turning in the hole (have tried another bolt).
The wheel bolt is M12x1.25.
Save having to spend over £100 replacing two perfectly good discs and pads, is it an option to repair the thread with a helicoil/thread insert or to re-tap the hole as M12x1.75 and just get a different wheel bolt for a couple of £ until these discs and pads need replacing? 2015 Range Rover Autobiography 4.4 SDV8
Post #646596 26th Oct 2022 7:22pm
Merchy
As long as it is done properly a helicoil should be ok. We use helicoils for some critical stuff at sea, never had a problem with them. Thumbs Up
Post #646601 26th Oct 2022 8:19pm
garyRR
Excellent. I'll whip off the disc and get it on the pillar drill. 2015 Range Rover Autobiography 4.4 SDV8
Post #646637 27th Oct 2022 5:26pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
If it helps, I believe the wheel bolts on Ifor Williams trailers are M14. Might help if your stuck.
Post #646646 27th Oct 2022 6:34pm
