![]() | Home > My Range Rover > Pete's new to him Autobiography Four Hundred and Five SDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8512 ![]() ![]() ![]() |
Did fatty mind the sub zero temps... well, I saw -8c on the dash and fatty always started and warmed the inside well with the FBH, I was very impressed...
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
Where did you source the grille from Pete, Happy New Year |
Pattern part obviously, fits perfect, you will need a grille badge, they are too well stuck on to reuse the old one.
Thanks Pete |
The grille fits on with several trim clips, in this weather it's best to warm them up before you try to prize the middle of the clip upwards until the clip comes out, and use a plastic trim tool or you will damage them, undo all the ones you can see on the slam panel then pull the grille off forward, only takes a few minutes... |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
Happy new year Pete, all. Just done the same with mine re the grill, really transforms the front end, pleased with the result. |
Yep, I really like it, the standard one looks too much like a Discovery grille to me...!! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
I did have one of those on mine for a while, but then found a used genuine SVO grill on EBay for not very many pennies. So thats been on mine for a couple of years now. There is nothing that can't be fixed with a hammer😜😜
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
mine [like petes style] which i've had for a few years now is losing the silver paint ..still looks ok though.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7896 ![]() ![]() ![]() |
I’m not normally one for aftermarket grilles, but I like that one.
It does look nice, and that's a blown up picture from the security cameras so far from HD...!!!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Having owned several L322’s, how do you find the L405, Pete?
