![]() | Home > Technical (L322) > Parking Assist Module error - U3002-81 |
icarus76 Member Since: 07 Oct 2018 Location: Solihull Posts: 29 ![]() ![]() ![]() |
Hi All,
Thanks for the reply, that is the unfortunate conclusion I am coming to.. strange as I've read lots of posts on various sites from ppl happily replacing the PAM with 2nd user units with no issue..
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
A lucky Ebay find.. |
Thanks again - looks like I'm part hunting again.. |
Amusingly, it didn't fix the problem straight away. Well, in combination with replacing corroded connector pins, it did. |
I had no idea they were locked to the car VIN. If you have had water damage once you will get it again......
Nor did I..
Don't discount capillary action up the harness, especially if there's no other sign of ingress and you had a corroded connector - possibly on the pin(s) that supply power or ground via a splice in the harness. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
This is very odd - I bought a salvaged module from eBay and plugged it straight in no problems at all.
It is certainly very odd - I asked IID and they can't reset it so I'm very doubtful breakers are... |
It'll work fine (providing that it was the cause of the issue) but may set a DTC for incorrect VIN. The reason being is that, if it has already been replaced by a dealer during it's warranty period and wasn't tied to the vehicle as they're essentially plug & go, then that would give you a PAM that is VIN-free, the PAM functionality isn't at all restricted by not having any or the incorrect VIN but it will make those who like to spend their time searching for errant DTC's twitch... |
The point of the post is it doesn't work fine though - if it was just throwing an error code I wouldn't care (plenty of those from other systems without issue). |
Well it's probably not the PAM then.
what makes you say that when when I can successfully query all live values (sensors, switches etc) and the only error being reported is the VIN mismatch one? Another user has also confirmed they had the exact same issue and had to purchase a 'virgin' unit.
