Home > Technical (L322) > Correct BMS coding for 90/95Ah 850CCA AGM battery?
In Vogue
Vehicle; 2011 RR Vogue 4.4TDV8.
Could anyone please confirm whether the BMS code "H8HD 90Ah 950 cold cranking ampere" is correct/the closest to the standard LR AGM battery which is designated 90Ah 850 CCA? It is noted there is a CCA value difference and also no mention of "AGM".
Also, is there an alternative/closer BMS code listed which would match the Exide EK950 AGM battery, designated 95Ah, 850CCA?
Post #645852 18th Oct 2022 8:29am
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
I’d also be interested to know that. I changed my battery to a genuine battery from the dealer - an Exide AGM 90Ah 850A and with the IID tool I reset the battery type to - Varta 90Ah 950.
Post #646026 20th Oct 2022 10:36am
JayGee
I'll check but I think the only crucial details are the numbers and not the make. 2012 TDV8 Vogue (L322)
Post #646027 20th Oct 2022 10:42am
