![]() | Home > Maintenance & Mods (L322) > Deployable Side Steps fitted… roof button goes where? |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
Mine looks quite ok.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Mine doesnt quite sit right. The thin plastic allows the two ends to flex, therefore sit slightly proud in places.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
just a thought,
Cheers cass and Stan for your thoughts. The button is in place and tbh I haven’t really noticed the poor fit, so will leave it as is… but will continue to keep an eye out for its proper replacement.
you should do a little bigger hole the inner parts are to tight and cover bends itself outside |
Do you mean the hole i cut for the button?
you need to do more space for this metal clips. sides leave as is. |
