Home > Technical (L322) > TDV8 3.6 MAF and Fuel Pressure Readings |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 678 |
My old 3.6 tdv8 did exactly as you are speaking following split intercooler hose.
14th Oct 2022 3:15pm |
Mattwales Member Since: 12 Oct 2022 Location: S Wales Posts: 4 |
Thanks for the reply, I’m half way through your thread. Need to read it all properly to understand and apply to my case.
14th Oct 2022 3:42pm |
Cloyster Member Since: 08 Jul 2024 Location: Scotland Posts: 4 |
Hello, did you managed to get this issue sorted? I’m having the same problem but getting the code Р0489-00 for Exhaust Gas Recirculation (EGR) control circuit low and in restricted performance all the time |
8th Jul 2024 6:39pm |
I never did figure mine out and ended up trading in for a facelift 3.6 as mentioned above.
8th Jul 2024 7:56pm |
Mines is a 3.6 2010 facelift, hoping it’s maybe related to the EGR then |
8th Jul 2024 8:24pm |
As yours is a 3.6 tdv8 you could physically blank the EGRs and map them out.
8th Jul 2024 8:32pm |
With the fault code you are getting I reckon one of your EGRs is sticking/has failed.
8th Jul 2024 8:42pm |
