![]() | Home > Technical (L322) > TDV8 3.6 MAF and Fuel Pressure Readings |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 730 ![]() ![]() |
My old 3.6 tdv8 did exactly as you are speaking following split intercooler hose.
Mattwales Member Since: 12 Oct 2022 Location: S Wales Posts: 4 ![]() ![]() ![]() |
Thanks for the reply, I’m half way through your thread. Need to read it all properly to understand and apply to my case.
Cloyster Member Since: 08 Jul 2024 Location: Scotland Posts: 4 ![]() ![]() |
Hello, did you managed to get this issue sorted? I’m having the same problem but getting the code Р0489-00 for Exhaust Gas Recirculation (EGR) control circuit low and in restricted performance all the time |
I never did figure mine out and ended up trading in for a facelift 3.6 as mentioned above.
Mines is a 3.6 2010 facelift, hoping it’s maybe related to the EGR then |
As yours is a 3.6 tdv8 you could physically blank the EGRs and map them out.
With the fault code you are getting I reckon one of your EGRs is sticking/has failed.
