Home > Technical (L322) > Solution: Key won't turn
JasonRSA
South Africa 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Thought I'd share recent experience.
My RR came with one key - an aftermarket unit.
The RR would have trouble every now and then with the key not turning in ignition.
Then escalated to the steering wheel lock not releasing after finally starting. I'd pull off and wheel locked!
Locking and unlocking doors was not a problem.
Last straw was being stuck at an airfield in Pretoria in high temperatures with a meeting to get to.
I tried all the DIY tips on the webs:
- short wire from steering column to cabin footwell light.
- spray WD40 everywhere
- bang stuff with a mallet
- burn incense
- bought an override unit from Turkey (meant to plug into the harness and solve all the issues).
Problem persisted. I then figured it may be the battery in the key, so as I split the key fob (in my front garden) I managed to lose the transponder somewhere in the flower beds. It's similar in size to your small finger nail. Vehicle now stuck in my driveway.
Phoned the locksmith. He needed the ignition ECU located inside the centre console. White case the size of a cigarette box.
Found this thread very helpful, but note there are two more screws to deal with towards the end.
Locksmith managed to programme a new transponder.
RR started first time and every time since. It's been two weeks now.
My thinking is the transponder is the problem - perhaps dodgy replacement by previous owner, age related...?
I've since had another key cloned and no further issues with either key.
Hopefully this helps someone.
Post #644298 29th Sep 2022 11:26am
Now I've read that it sort of sounds obvious, I totally appreciate it isn't but it goes to show you have to start with the basics...
Never heard of the chip failing but then maybe it had lots of times and got overlooked...
Glad it's sorted and hope it stays that way... Thumbs Up Pete
Post #644314 29th Sep 2022 4:10pm
TDV8 Paul
‘Banged stuff with a mallet and burned incense’ tickled me 😂
Glad you got it sorted 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #644508 1st Oct 2022 7:48pm
