Home > Technical (L322) > 2011 TDV8 Drivers door module programming
Fur3rd
So i stupidly left my driver's window down in a rainstorm, and filled the driver's door control module with water. This meant i had the following issues
Window wouldn't close
door wouldn't lock or unlock with remote or button in centre
mirror wouldn't fold
I ordered a replacement with identical numbers on. Fitted it and now window goes up and down, but drivers side rear door doesn't lock neither does drives door and the car beeps upon locking to say door is open. Replaced module with another one and still have the same issues.
Upon discovering this i took my original apart and cleaned all the corrosion up on the board and reinstalled it. This fixed the window working but in now only goes down by 2 inches before you need to press switch again and then goes down another 2 inches, but drivers door mirror doesnt fold and door wont lock
Do the new replacement modules need to be programmed to the car if so how do i do this i have a IID tool
Many thanks in advance
Post #644281 29th Sep 2022 8:21am
Googs
Australia
I'm sorry i don't the answer to your question
If it were me i would just fit it and i'm sure everything will work.
Someone will chime in to help you out. Very Happy 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #644442 30th Sep 2022 6:22pm
Phoenix
Possibly water in the connectors or door lock?
Post #644444 30th Sep 2022 6:26pm
After you fit one, try a battery disconnection, this may help to sort it, I had the window drop 2" at a time issue and it sorted that...
Then, as the manual says.....
Once the power supply is restored, reset the windows as follows:
Close the window fully.
Release the switch, then lift it to the close position. Hold for 2 seconds.
Release the switch.
Repeat the lift and release procedure twice more. (first time usually does the job)
Test the window for correct manual and automatic switch operation.
Repeat the procedure on each window. Pete
Post #644451 30th Sep 2022 8:34pm
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
On my car 2012 TDV8 when the modules have been reset or power disconnected I have to use the GAP tool to re program the windows.
There is the option in calibration for the drivers window, when you run it it first does both the windows on one side, down and up then it does the other side.
give that a try and see if it resolves your issue. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #644468 1st Oct 2022 8:46am
Fur3rd
cheers, i ve not had a lot of chance to look as my son was diagnosed with Leukemia, so been running him forward and back to hospital, but hopefully will get 5 to look soon
Post #644882 6th Oct 2022 6:04am
Googs
Australia
Sorry to hear about your Son, hope his treatment isn't too hard on him and he gets some real benefit from it! 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #644887 6th Oct 2022 7:52am
Musab
Iraq
Do you fixed the problem because I have some problem and I hope your son recovers as soon as possible.
Post #710475 28th Jan 2025 8:53pm
