Home > Maintenance & Mods (L405) > iiD cheaper alternative
Gremlin500
Hi, I,ve been looking around at alternatives for the iiD diagnostic tool due to possible excessive earache from SWIMBO and decided to go for the iCarSoft LRV3 tool which I got for £150 from their official distributor in France with free delivery on eBay. This new latest version comes with a whole host of upgrades and improvements and can handle the usual stuff like Service resets, plus TPMS, suspension resets, ABS bleeding, etc. so it’s very close to the iiD tool, but for a third of the price with lifetime upgrades for free.
I’m about to do a battery replacement tomorrow on our L405, so I’ll report back and see how it goes.
I got a cool smart battery tester from AliExpress which quickly diagnosed 39% remaining SOH for only £28 without the need to remove the battery from the car. I had suspected battery issues following sluggish tailgate operation, and the fact that my CTEK MXS5.0 was taking a long time to move from phase 4 to phase 6 on the display.
If everything works OK, I’ll post up a response with links soon………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #642633 11th Sep 2022 12:05am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Super interesting, I wonder if it works for 2018+... There is no mention of that on the site...
https://www.icarsoft.eu/LR-V3
Post #642649 11th Sep 2022 10:12am
Kot
GAP dont work for my MY2018
I use this, cheap as chips it clears DTC found it very useful, it also has other functions read the blurb for full info
https://www.autelstore.co.uk/wholesale/aut...anner.html 2018 SE SDV8 4.4 Byron Blue
Post #642677 11th Sep 2022 2:44pm
Gremlin500
Update:
Replaced the main battery today and updated the BMS, very straightforward, didn’t even bother to look at the manual.
Then did a “Quick Check” diagnostic, it found a few historic DTC’s so I cleared those, again really straightforward.
I then ran a full scan, which took about 5-10 mins and everything said “PASS” Happy Days!
Seems like this is a real contender now they added the latest updates lacking in the V2 version.
The French distributor even gives you a freebie ruggedised data extension cable, and is £30 cheaper than the UK, it did take a week to arrive though.
£150 well spent IMHO. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #642691 11th Sep 2022 5:28pm
Gremlin500
Sorry, forgot to say, this product is not VIN-restricted, so you can use it on any compatible JLR vehicle. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #642692 11th Sep 2022 5:30pm
Phoenix
Sounds interesting, I may be on the lookout for a replacement for my ageing Autologic as the touchscreen has been playing up of late - can you edit the CCF / customer options etc.?
Post #642697 11th Sep 2022 6:25pm
Gremlin500
@Phoenix,
This seems more of a "Service Tool" than a "Tinkering Tool", i.e. "Is my car OK?" rather than tweaking it.
You can check it's abilities on their website, certain JLR features in the bus are locked by JLR for obvious reasons, I don't know if the iiD tool or even Chinese hacked "P*thF*nder" software can unlock features "wired for but not paid for", for example. I am not an expert in diagnostic software by any means, today was only my first amateur experience.
The important observation to make here is cost vs benefits. Thumbs Up
Perhaps others more knowledgeable than me can comment? Bow down “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #642723 11th Sep 2022 9:53pm
Phoenix
Ah, right - thanks for that, I have an Autel 'all makes' DTC reader and a TPMS tool, both do significantly more that their website suggests so I was wondering if this was the same sort of 'underselling' on their website, it does read as a diag-only tool.
It does seem good value if you don't have the urge to twiddle & tweak things!
Post #642729 12th Sep 2022 7:31am
Gremlin500
Perhaps this will help others:
Post #642735 12th Sep 2022 9:18am
Gremlin500
Um, that’s not terribly easy on the eyes, is it? Embarassed
Try this link instead:
https://www.icarsoft.com/Article/s-126-126.html
Post #642861 13th Sep 2022 1:35pm
Jayk69
I like iCarsoft my only problem with them is when they change version IE from V2 to V3 you have to get a new one they DONOT update the tool. i have had V1 and V2 and to get the benefits of the V3 i would have to spend again by which time i should have brought IID Shocked 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #642862 13th Sep 2022 1:46pm
Gremlin500
I downloaded and updated the software on my new V3, but clueless if it added any extra features or functionality, as I’d not even used it before doing so Embarassed There don’t seem to be any Release Notes or ReadMe notes for updates, they just appear as available downloads…. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #642957 14th Sep 2022 7:07pm
Gremlin500
UPDATE ON iCarSoft LRV3 TOOL:
Censored
Well, following a recent interim 6-month oil & filter change by yours truly, I must report this tool FAILED on multiple occasions to reset my MY2017 oil service, (as did the doors/bonnet/pedals/tug one’s forelock/say 3 hail Marys method) Maybe it works for earlier models, but not 2017.
Contacted the developer, and after an initial response asking for data log which I immediately provided, zero response to date.
I therefore can NOT recommend this tool other than as a simple DTC scanner, which I already had in the form of the most excellent little Vgate iCar Pro BT module, (under a tenner on AE).
Now saving up for an iiD BT tool Embarassed Embarassed Embarassed
If anyone has had a better experience with this tool, please post here and I will edit this post accordingly, thanks guys! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678314 19th Nov 2023 11:52pm
caymanblack
Thank you for the update Gremlin. overfinch modified
Post #678322 20th Nov 2023 10:46am
knwatkins
After my IIDtool got stolen, I couldn't justify buying another so likewise, I bought the Autel AP200.
Bargain at £50.
Whilst I haven't used it in anger, I've used it for service resets, putting the air suspension into TTM, reading and clearing codes etc.
Might be a worthy consideration for you Gremlin?
I've taken the train of thought that if the Autel does everything I need it to on a day to day basis then it may suffice for the whole time I own the car. If I really, really need another IID I'll just buy one if the time comes (which it may never do). Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #678328 20th Nov 2023 1:41pm
