Home > Technical (L322) > Oh happy days ... blasted thing !
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
I had one of those mornings where I was swearing at my car and threatening it with the classified ads ! lol
Early morning, dark and damp, blasted heater fan has packed in (again) and now the entire right half of heated screen doesn't work.....
75 miles later and getting to my destination I'd forgiven it...well nearly. This is going to be expensive I thought...
Post #572596 12th Nov 2020 6:46pm
mjdronfield
Thought you’d gone the full Basil Fawlty there, and threatened it with a tree branch.
I think the screen has a connection each side if I remember right. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572616 12th Nov 2020 9:06pm
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Didn't realise the screens had a connection on both sides, half of my screen has stopped working so this may be worth investigation.... Current FF Westminster 4.4 V8
Post #572655 13th Nov 2020 11:27am
Ragingrover
I assume that the connections are below the wiper panel, at lest thats how I've seen other manufacturers connect for wiper area screen heaters... being Landrover they're probably via the rear lights ! lol
Post #572656 13th Nov 2020 11:35am
on the L405 and probably the same on yours , the connections are at the bottom of the inside 'A' pillars.. ... - .- -.
Post #572661 13th Nov 2020 12:16pm
Ragingrover
So if the windscreen is replaced then the interior gets stripped too ?? I've not had mine done yet but it needs doing, been putting it off
Post #572662 13th Nov 2020 12:18pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Heated Screen Elements
I’ve just discovered that a whole bank of heating elements directly in the drivers view are not working…. So it seems the issue may be with the RHS connector at the bottom of the A-Pillar.
I plan to inspect the wire connections in the connector to check for pin push back or wire breakage.
Does anyone know how the connection from the wire to the screen elements is made?
Are they fragile and likely to brake away ?
Here’s what I found in the work shop manual :
 TDV8 4.4 2012
Post #643757 23rd Sep 2022 10:14pm
Phoenix
Check the fuse first...
Post #643758 23rd Sep 2022 10:37pm
