Home > Technical (L322) > Oh happy days ... blasted thing ! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
Thought you’d gone the full Basil Fawlty there, and threatened it with a tree branch.
12th Nov 2020 8:06pm |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 |
Didn't realise the screens had a connection on both sides, half of my screen has stopped working so this may be worth investigation.... Current FF Westminster 4.4 V8 |
13th Nov 2020 10:27am |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 |
I assume that the connections are below the wiper panel, at lest thats how I've seen other manufacturers connect for wiper area screen heaters... being Landrover they're probably via the rear lights ! lol |
13th Nov 2020 10:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
on the L405 and probably the same on yours , the connections are at the bottom of the inside 'A' pillars.. ... - .- -.
13th Nov 2020 11:16am |
So if the windscreen is replaced then the interior gets stripped too ?? I've not had mine done yet but it needs doing, been putting it off |
13th Nov 2020 11:18am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
I’ve just discovered that a whole bank of heating elements directly in the drivers view are not working…. So it seems the issue may be with the RHS connector at the bottom of the A-Pillar.
23rd Sep 2022 9:14pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Check the fuse first... |
23rd Sep 2022 9:37pm |
