Home > Maintenance & Mods (L322) > 4 short intake hoses!
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
So over the weekend I’ve had the reduced performance pop up on the dash and thanks to this forum have found a split intake pipe on the n/s/r of the doughnut I’ll replace all four as there the older style I’ve gathered from other posts.
I’ve also found there 70mm inside diameter but was wondering if anyone can point me in the direction of the length of these pipes?
I’ve found these and wondered if these will do the job better than the originals in there?
https://www.ebay.co.uk/itm/194091569249?mk...media=COPY
Any help appreciated Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #641586 31st Aug 2022 8:29pm
GraemeS
I made mine 60mm long but 55mm would make them easier to fit.
I re-used the original clamps.
I don't see any need for the flexible section which would have to be cut each end to make them short enough.
Post #641589 31st Aug 2022 8:44pm
RRV78
Thank you for your reply. So I’m best off just getting some straight pipe and cutting 4 55mm pieces then. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #641590 31st Aug 2022 8:52pm
GraemeS
That's what I did at a fraction of the cost of new genuine hoses.
Post #641635 1st Sep 2022 10:04am
RRV78
Pipe arrived today so the weekends job is all set to go. If the weather holds out Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #642090 5th Sep 2022 6:50pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
@RRV78 Did you buy straight pipe, if so do you have a link?? Thumbs Up Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #642205 6th Sep 2022 4:12pm
RRV78
https://www.ebay.co.uk/itm/195144378435?mk...media=COPY
Hope that helps! My job this weekend to fit them. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #642208 6th Sep 2022 4:40pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ve just fitted the Land Rover ones I bought a while back and they seem quite a bit shorter than the old ones - I hope there’s enough grippage.
Post #642214 6th Sep 2022 5:15pm
grayst01
@RRV78 Ordered! Many thanks... another wee 'to-do' coming up... Rolling Eyes Cheers, Steven.
Post #642236 6th Sep 2022 9:42pm
