Home > Technical (L405) > Traction Reduced Message on Start Up (almost every time)
neilp
England 2014 Range Rover Vogue TDV6 Luxor
Any thoughts/help?
2020 4.4 diesel FFRR
Had it 2 months - last 48 hours when I start it I get a Reduced Traction warning on starting the engine.
Everything seems fine when driving..
Im awaiting a call back from my local dealer but im keen to know the groups thoughts? is this going to be a software issue? is it well known? ive done some googling and cant find anything recent for a FFRR.
Post #642147 6th Sep 2022 10:22am
i've done a forum search and any ref to this message is related to the L322..on those threads it seems a new battery has solved this problem.. ... - .- -.
Post #642150 6th Sep 2022 10:52am
dhallworth
Like Stan says, every time I've had this on my L322 it was due to the battery voltage dipping when starting the car.
Might be worth getting your car on a C-Tek or similar smart charger to ensure the battery is at full charge to see if it cures the issue.
2013 Range Rover Sport SDV6 HSE Luxury in Santorini Black with Jet Interior
Post #642152 6th Sep 2022 10:56am
neilp
thanks - im now booked in at my local dealer but not till next week!
im planning a big trip up to Scotland in 10 days for 5 days - so im a bit panicky this is something critical... dont want to break down in the highlands or islands...
if its battery thats ok.. however ive found an old Freelander report it was a defective rear diff!!
Post #642154 6th Sep 2022 11:02am
dingg1
It can be motor failure on the rear ediff, but the car can still be used, need the codes read tbh as dodgy wheel speed sensor can also be the issue.
Post #642158 6th Sep 2022 11:14am
dhallworth
If your car is only 2 years old, give Land Rover assistance a call and ask them to come out. They'll come to you rather then you having to wait until your dealer is able to see you.
Explain that you're concerned you might be doing damage and that you have a trip to Scotland planned.
Post #642159 6th Sep 2022 11:18am
good idea David.. Thumbs Up ... - .- -.
Post #642160 6th Sep 2022 11:19am
neilp
I didn't realise I could do that - slaps head! also why didn't dealer mention it.. ill give them a ring! thanks!!!
Post #642161 6th Sep 2022 11:22am
neilp
ive rung LRA and they are coming late pm.. will their person be able to tell these from a code read? do they carry that level of kit?
Post #642164 6th Sep 2022 11:40am
they are pretty good Neil so i reckon the will be able to tell you whats wrong.. ... - .- -.
Post #642165 6th Sep 2022 11:55am
neilp
Great - ill let you know what they say - thanks for amazing help!
Post #642167 6th Sep 2022 12:16pm
dhallworth
Code reading is the first step of diagnosing anything these days so they will be carrying proper diagnostics.
Fingers crossed it’s something as simple as a weak battery for you.
Post #642169 6th Sep 2022 12:18pm
neilp
ok so update.
LRA came an hour perfectly on time - love their system
lovely chap Steve - as you say laptop code reader that as far as I could see over his shoulder was top of the line - appeared to check all my firmware was up to date - which is good to know..
problem appears to be the motor to the e-diff - so well done dingg1
Steve then proceeded to mess around under the car for 20 mins - came back up saying he felt ?the sensor was loose - and then tested the car for another 30 mins.... and so far no more warning light.
ive taken it for an hours drive - to drop off my daughter and it seems ok.... so hopefully.... thats it..
my question now is do I ask the Dealer to look at the e-diff anyway - or has Steve fixed it?
Post #642209 6th Sep 2022 4:59pm
dingg1
If it doesn't alarm anymore then you can consider it fixed, you can still drive if the ediff motor is not working anyway, enjoy Thumbs Up
Post #642210 6th Sep 2022 5:01pm
neilp
Cool
Post #642212 6th Sep 2022 5:13pm
