![]() | Home > Technical (L405) > Traction Reduced Message on Start Up (almost every time) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
i've done a forum search and any ref to this message is related to the L322..on those threads it seems a new battery has solved this problem.. ... - .- -.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3176 ![]() ![]() ![]() |
Like Stan says, every time I've had this on my L322 it was due to the battery voltage dipping when starting the car.
neilp Member Since: 24 Feb 2018 Location: Nantwich Posts: 12 ![]() ![]() ![]() |
thanks - im now booked in at my local dealer but not till next week!
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1361 ![]() ![]() |
It can be motor failure on the rear ediff, but the car can still be used, need the codes read tbh as dodgy wheel speed sensor can also be the issue. |
If your car is only 2 years old, give Land Rover assistance a call and ask them to come out. They'll come to you rather then you having to wait until your dealer is able to see you.
good idea David.. |
I didn't realise I could do that - slaps head! also why didn't dealer mention it.. ill give them a ring! thanks!!! |
ive rung LRA and they are coming late pm.. will their person be able to tell these from a code read? do they carry that level of kit? |
they are pretty good Neil so i reckon the will be able to tell you whats wrong.. ... - .- -.
Great - ill let you know what they say - thanks for amazing help! |
Code reading is the first step of diagnosing anything these days so they will be carrying proper diagnostics.
ok so update.
If it doesn't alarm anymore then you can consider it fixed, you can still drive if the ediff motor is not working anyway, enjoy |
