Home > In Car Electronics (L322) > Apologies, but newbie (here) with another screen thread !
Maverick1141
United States 2010 Range Rover HSE 5.0 V8 Ipanema Sand
Guys, thanks for looking.
2010 5.0 NA in New York.
Lifetime LR owner and third L322.
I have tried the search option on here!
So last week my car popped up with a 'charging system fault' bong on the dash while driving. Everything was functioning correctly at the time, NAV, stereo, centre screen and commands were all working ok.
My immediate reaction was to shut down all electrical systems, lights, fan, Nav screen with red cross, etc.
I parked and got the car recovered and had the alternator (not charging) and battery replaced and coded.
PROBLEM: The centre screen has not come back on since.
I have no life in the screen now at any point. The power button is NOT flashing.
I have checked the rear left compartment and it's bone dry and all appears plugged in correctly.
ALL fuses individually checked and all ok.
I have tried disconnecting the battery overnight. I have tried disconnecting and touching the battery leads together.
Car has no codes recorded, according to my RSW Solutions and also my Euro-centric shop's code reader, including doing a reset on all modules and my shop could 'see' the radio module. The buttons around the screen are backlit when lights are on, and the hazard switch is back lit. Centre locking button works fine.
I have checked the top module in the rear left and have red light at the fibreoptic plug. I've bought a MOST loop to check the other modules.
Local stealer suggested a disconnect and restart, as they have no one qualified to work on anything 'that old'... Sad
To quote on one of the other posters here, is there a 'secret handshake' I'm missing to get the screen etc back on please?
Thanks ladies and gents, stay safe,
Mav
Post #647872 11th Nov 2022 4:04am
DAZFINCH
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Hello Mav. Unfortunately we are experiencing the same problem as you have encouintered.
No power light screen blank infotainment system Following the vehicle having had a battery disconnect.
2011 4.4 Diesel. UK car
All the usual checks looked into to, no joy with this, have a feeling that this will transpire into something
outside of the usual optical bluetooth and other component failure.
I was hoping that you may have resolved your problem and may be able to shed some light on this.
Many thanks in advance.
Regards Daz
Post #651653 26th Dec 2022 11:59am
You should have some fault codes, get it scanned and start from there... Thumbs Up Pete
-Click here for Thread-
Post #651690 26th Dec 2022 9:47pm
Maverick1141
Pete, thank you. As I said above, RSW and my (non-JLR) local shop scanner reveal no codes, BUT, i do now have a flashing power button and static 'RANGE ROVER' logo on the screen.
Thanks, Mav
Post #651691 26th Dec 2022 10:23pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That sounds hopeful. Have you tried disconnecting & reconnected the rear control modules to see if that brings the screen back into life.
Post #651702 27th Dec 2022 10:09am
