Home > Technical (L322) > Is this amount of rust normal? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Thats normal for a 15 year old car |
4th Sep 2022 9:07pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
Cool thanks. So guessing mostly surface rust.
4th Sep 2022 9:12pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3106 |
The rust in your first picture is on the exhaust, in the 2nd picture it’s on a shock absorber, and in the 3rd it’s on the exhaust again and the rear wishbones.
Thanks.
4th Sep 2022 9:14pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2571 |
4th Sep 2022 9:41pm |
Great thanks.
4th Sep 2022 11:41pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 585 |
I would go along with what David said, except your car is much rustier than mine in those three areas so check under the cill covers, mine are quite bad yet the rest of the car looks better than yours.
5th Sep 2022 12:22am |
Ok thanks. Thought it looked like it all needs changing sooner rather than later.
5th Sep 2022 8:04am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8248 |
The bad rust happens behind the plastic sill panel, get a trim tool and pull the trim away where the red line is, you only have to pull it an inch or so, then use a torch and look down behind where the arrow is...
5th Sep 2022 11:12am |
Great advice.
5th Sep 2022 11:18am |
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 |
I've been through this recently... as has been said above the only way of knowing is to take off the trim. Mine car looked OK no sign of any rust.. but underneath the trim I was greater with this.
5th Sep 2022 12:50pm |
Good to know.
5th Sep 2022 12:53pm |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 |
Just went to see a low milage (60K miles) 2009 FFRR in Buckingham Blue in decent condition. It had some brief tailgate rust but also at the rear arches, and only at this spot. The car also had deployable sidesteps.
30th Sep 2023 4:48pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Typical for these cars which were never designed to last more than 5 years...... 2012 TDV8 Vogue (L322) |
1st Oct 2023 8:51am |
