Home > Maintenance & Mods (L322) > 2008 vogue headlight lens
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Hi all
Other than the stick-it-in-the-oven routine, is there an easy way to remove just the lens from the headlight units? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #641071 27th Aug 2022 2:12pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
You could try using a hot air gun gently & see if it releases from the backing.
Post #641073 27th Aug 2022 2:27pm
tymh
👍 Tym
Post #641075 27th Aug 2022 2:40pm
tymh
That said, I’d probably melt this unit! Tym
Post #641077 27th Aug 2022 2:48pm
garyRR
Hairdryer so that you don't melt it, plus a fresh blade on a Stanley knife, plus a plastic trim removal tool. 2015 Range Rover Autobiography 4.4 SDV8
Post #641092 27th Aug 2022 4:28pm
tymh
I was contemplating that actually Gary. Think I’ll make a day of it when the new SVA style grilles come. Got led indicators and side lights to fit and want to dismantle the headlights to put angel eyes in plus maybe auxiliary dynamic indicators. Should be able to do it all in one go then… Tym
Post #641119 27th Aug 2022 6:20pm
garyRR
LED sidelight and indicator bulbs will bring up a Canbus error so, not worth bothering (I tried on my 2006).
Side indicators will not because they're not Canbus monitored I believe.
Maybe try and fit the 2010-2012 style lights to the car? They have the fairy lights and won't look a bit "Halfords", because they'll be in-keeping with the facelift?
Post #641125 27th Aug 2022 6:28pm
tymh
These are sold as error free so I'll see how they go.
If they produce errors - they go back! Tym
Post #641126 27th Aug 2022 6:33pm
tymh
These are the side lights
[url] https://www.ebay.co.uk/itm/334364188281?mk...COPY[/url] Tym
Post #641142 27th Aug 2022 9:14pm
