Home > Technical (L405) > This from the rear
here's the tsb relating to fuel slap..
https://www.fullfatrr.com/gallery/albums/u...hud%20.pdf ... - .- -.
Post #641129 27th Aug 2022 6:52pm
Gremlin500
@Stan, well researched, re that thread.
Makes me wonder, did they have a certain batch of poorly-baffled tanks over a certain build range, and if so, which vehicles were affected?
And wondering further:-
I wouldn’t be happy at someone stuffing a load of foam down the filler pipe, foam is plastic and diesel/petrol a hydrocarbon solvent, so what happens over time, if the foam starts to break down in there? Shocked
I know, I’m paranoid. Big Cry Sad
Easier to keep the tank topped up, also very useful when heading for the hills come Armageddon…….. Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #641136 27th Aug 2022 8:03pm
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Lol get you there! Is there a good way to replicate tank slap? I mean I get tank half full but then like reverse then straight in to drive etc, the thuds I have is about 40 seconds after driving off etc
Post #641137 27th Aug 2022 8:06pm
Phoenix
It's a similar type of foam the MoD should have been putting in the C130 wing tanks - would've save a few mate's lives.
Anyway, it takes up a couple of litres of capacity, is a pain in the @rse to fit and doesn't degrade or block filters, it's not the same as the stuff cheap mattresses are made from.
Post #641138 27th Aug 2022 8:18pm
Gremlin500
40 seconds doesn’t sound like fuel slosh at all, which would be almost instantaneous after acceleration/deceleration, max 1-2s I would have thought. Maybe an auto gearbox issue, have you flushed/changed fluids in good time? “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #641148 27th Aug 2022 9:48pm
