Home > My Range Rover > My 2011 Range Rover L322 4.4 TDV8 Vogue SE story
Page 2 of 4 <1234>
Mr Tee
Fuel device pops back in with a long thin screwdriver dead easy Thumbs Up
Post #640186 19th Aug 2022 1:26pm
Thanks, I thought it might... Thumbs Up
Second day of ownership, no bong of doom just... "suspension fault max speed 30mph" suspension dropped a bit, not to access height but lower than usual and it went rock hard....
Tried a switch off and back on to no effect so drove home, then it kept saying "suspension will raise when system has cooled"
Oh well, have to get an IID straight away.... Pete
Post #640191 19th Aug 2022 2:13pm
johnboyairey
Pete, a warm welcome back friend. those rear shocks, are a bit of a mystery. and quite expensive. you need to speak to Sam from 'Sam's motor and machine' channel on youtube, he has a saga on here, with his rear shocks, and will no doubt have some advice.
Post #640196 19th Aug 2022 3:11pm
johnboyairey
Haylands wrote:
Lol... it is still on the list... much longer fuel stops as the device that stops you putting petrol in has been triggered and the tool is nowhere to be found...!!
yellow tool should be in the boot, under the wheel cover, on right in a slot.
Post #640198 19th Aug 2022 3:17pm
JayGee
Rear shocks ( genuine Bilstein) are £200+VAT each from Island 4x4 and more ( a lot more) from other places. Fitting them is pretty easy DIY as long as the lower bolt is not seized. Aux belts , idlers and tensioner replacement is a normal wear item on these engines but DIY is a bit tricky due to the amount stuff to remove to get to it. Check for oil leak down the back of the engine and oil in the coolant expansion tank as the other common fail is the oil cooler but you may be lucky and it's already been done. Rest should be no different to your SC. 2012 TDV8 Vogue (L322)
Post #640200 19th Aug 2022 3:38pm
John, I know where it should be but it is missing in action and has left the building... Rolling with laughter It's good to be back...
JayGee, cheers for the info, shame it's £200 PLUS Vat, still a reasonable price though...not sure if it is failed shocks, could be the dodgy wiring problem, I've not looked yet.. I'm more than happy to do some work on it, it will soon be kicked into shape...
Cooler looks new and seems bone dry from what I can see without dismantling anything and there is no burning oil smell so hopefully the O rings are Ok.
Idler replacement will be OK, I'll borrow a ramp from my mate and have it torn down no bother.... Thumbs Up
Suspension going rock hard is the last issue, suspension faulted then said "suspension will raise when system has cooled" which could indicate it has a leak and the compressor is working overtime to cope, it didn't drop an inch overnight though so it could be a few other things...
I need an IID to interrogate it...
It was a trade sale and some work was built into the deal so I'm more than happy to be back in a comfy and spacious fatty even if it does need some work... Thumbs Up Pete
Post #640206 19th Aug 2022 4:26pm
johnboyairey
i think the later 'active' bilstein dampers are more like £450 a pop. - as i said, watch/read Sam's dilemma.... https://www.fullfatrr.com/forum/topic59154.html
mine is fine, if i'm ever up your way, i drop in, and you can drive it.
Post #640216 19th Aug 2022 5:29pm
JayGee
I was quoting for the late active dampers but as I said the prices vary quite a bit depending the supplier.
https://www.island-4x4.co.uk/rear-shock-ab...23661.html 2012 TDV8 Vogue (L322)
Post #640218 19th Aug 2022 5:48pm
I certainly hope I don't have Sams issue, I feel for the guy.... Pete
Post #640219 19th Aug 2022 5:56pm
JayGee
Usual reason is the wiring at the top of the shocks - it's like all the wiring on these vehicles and has no sleeve on the last few inches so easily get severed with wear and insulator age. 2012 TDV8 Vogue (L322)
Post #640220 19th Aug 2022 6:01pm
I'm hoping it's that easy but I won't hold my breath....lol... Pete
Post #640222 19th Aug 2022 6:06pm
johnboyairey
..possibly, its the reason it was traded in. so, you might find, you got a car, with a problem, that you can sort, and the 'unknown' then becomes water under the bridge.
Post #640246 19th Aug 2022 10:49pm
Could be, either that or they were fed up taking an hour to fill it up with the missfuel device sprung...!!!
I had a quick look this morning, it's sitting slightly low on the front offside, started the engine and it raised about an inch or so, switched off and got near the front wheel... now, I'm not scared of snakes but there is no way I'm sticking my head under there, there must be a huge hissing Sid wrapped around the strut.... Laughing
It must be the usual place on the fold and it self seals at a certain height...
I think this is new as it drove 100miles home fine and overheated the compressor within 10 miles yesterday...
IID coming from Black Hawk Solutions as they seem to be the cheapest at the moment
more wallet bending items coming from Island 4x4...
Should be a fun week, I get to play with a fatty again....
I have to get a move on as my good lady is dying to have a drive...
Life is good.... Thumbs Up
Anyone know what this is/does...??
 Pete
Post #640277 20th Aug 2022 10:48am
JayGee
Looks like a speed camera detector....... 2012 TDV8 Vogue (L322)
Post #640285 20th Aug 2022 11:54am
Wiring to all four shocks is fine, no chaffing anywhere...
Fronts work fine, rears are very bouncy... I'll await the IID and see if anything comes up, otherwise new rear shocks to be fitted...
Can't do anything till Tuesday now so off to read the manual on the TDV8 engine.... sad, I know.... Laughing Pete
Post #640301 20th Aug 2022 2:25pm
Page 2 of 4 <1234>
