Home > Maintenance & Mods (L322) > coolant level low
Lee's Dad
Vatican
Rob2529 wrote:
Pret
Do you have a V8 or TD6?
Hover your mouse pointer over his little car below his avatar Thumbs Up
Post #78089 29th Aug 2011 4:32pm
Lee if you can tell me how that's done with an iPhone it would be much appreciated. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #78090 29th Aug 2011 4:34pm
Lee's Dad
Vatican
That i wouldn' t know, but just trying to be helpful.
Post #78092 29th Aug 2011 4:44pm
pretlove
ive got a v8 4.4 petrol Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #78132 29th Aug 2011 6:55pm
pretlove
thanks lees for trying to help "RANGEISM WILL NOT BE TOLERATED"
Post #78134 29th Aug 2011 6:56pm
Pret,
i've had a small leak from day one. Tracked it down to my LPG kit and also found a load of small leaks from the rear hose's and valley pan. Might be worth a look. Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #78145 29th Aug 2011 8:04pm
pretlove
i dont have lpg but i did follow your thread and when i get time i will check those places you mention.......ive found a small leak from the bottom of my rad ....it appears to be an overflow pipe on the bottom left corner "RANGEISM WILL NOT BE TOLERATED"
Post #78147 29th Aug 2011 8:10pm
Prob your rad. mine went and over time started to puddle under the car. Easy job to do and about £170 for a new one. Do you mean bottom left when your sat in the drivers seat? If it is think its from the alternator or the transmission stat. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #78152 29th Aug 2011 8:23pm
pretlove
yes it is the bootom left from the drivers seat ...theres a little metal pipe that comes off the rad and that drips a little but not much and not all the time "RANGEISM WILL NOT BE TOLERATED"
Post #78156 29th Aug 2011 8:53pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
The pipe you are looking at is the radiator drain, make sure the screw is tight or may be the o ring needs replacing.
Post #78363 30th Aug 2011 8:30pm
+1 Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #78408 30th Aug 2011 11:07pm
pretlove
thanks guys.....love your avatar rob Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #78510 31st Aug 2011 4:24pm
