Home > Technical (L322) > P132e21 Ccde live data reading fault
Croker
Spain
So having replaced with NEW Borg Warner turbos, checked all pipes for splits, replaced with new inlet manifolds and intercooler the car ran fine for approx 500km then the code came back. Initially it would show up after about 45 mins of driving from cold but now it shows up almost instantly. So, when putting the diagnostics on, there is a difference in the reading between bank 1 and bank 2 EVEN BEFORE starting the engine...then you will see the readings are lower on bank 1 until the engine is blipped then the fault kicks in and the pressure drops significantly.
See the youtube video.. [url=https://youtu.be/fynrBvp7JaY]
TDV8 3.6 2007 TDV8 3.6 2007 Vogue SE
Porsche Boxster 3.2S 2000
Porsche 928S 1986.5 Manual
Fiat Dino 2000 Coupe
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Honda Civic 1.8 Si 2006
Fantic Caballero 125 Scrambler Deluxe
Post #639664 15th Aug 2022 11:03am
