Home > In Car Electronics (L322) > 2011 Speaker part numbers.
daveturbo
My 2011 Range rover l322, lower door speakers are crackling like mad. Does anyone know the original LL part number or should i go for after market, many thanks. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #638684 4th Aug 2022 2:53pm
mjdronfield
Are they Logic 7 or Logic 7 HD?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #638688 4th Aug 2022 3:36pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #638692 4th Aug 2022 3:47pm
mjdronfield
You might need to double check… had that sheet for years 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #638693 4th Aug 2022 3:47pm
garyRR
Re: 2011 Speaker part numbers.
I've replaced loads now - really common for the low ranges to experience coil rub. They're XQM500170. They're about £50 each from main dealer.
I'm aware of only one retrofit part which is the GAS PS3M62 PRO SPL. You'll need to get them imported from Norway however. They're about €100 for a pair, plus shipping, plus VAT. They are apparently significantly better quality than the Harmon Kardon speakers.
You can actually replace these speakers without needing to remove the whole door card. Just remove the door card screws and pop off the lower trim clips and flex out the door card a bit and there's enough space to fit a small T20 Screwdriver inside to swap the speakers over. Takes about 5 minutes per door. There's 5 screws and 1 multiplug on the side of the speaker. 2015 Range Rover Autobiography 4.4 SDV8
Post #638731 5th Aug 2022 12:59am
daveturbo
speakers
Thank you very much guys ,going to order the genuine ones today. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #638750 5th Aug 2022 11:17am
garyRR
Sorry, a slight correction to my previous advice. XQM500170 was superceded by XQM500420 (I just found the part box in the garage and i have a brand new speaker I was unaware I had).
Ordering XQM500170 will still get you XQM500420 if from main dealer. 2015 Range Rover Autobiography 4.4 SDV8
Post #638977 7th Aug 2022 10:49pm
daveturbo
Speakers
Thank you Gary your correct, new part numbers. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #639269 11th Aug 2022 8:36am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Came across this thread whilst looking for info and thought I'd link it to the thread I posted a while back, on replacing this speaker with another option: https://www.fullfatrr.com/forum/topic57819.html
Hopefully useful to someone Smile
Post #656718 15th Feb 2023 11:07am
madnessgonemad
Hi, trying not to hijack this thread, but has anyone the spec and part numbers of the HD set up? I can’t find any information anywhere. 2012 L322 Westminster.
Post #656737 15th Feb 2023 1:52pm
Siftah
This thread has a full breakdown of the differences between the Logic 7 and Logic 7 HD: https://www.fullfatrr.com/forum/topic43436...logic+7+hd
Post #656756 15th Feb 2023 3:30pm
madnessgonemad
Thanks. Just what I need
Post #656808 15th Feb 2023 8:09pm
