Home > In Car Electronics (L322) > 2011 Speaker part numbers. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
Are they Logic 7 or Logic 7 HD?
4th Aug 2022 3:36pm |
4th Aug 2022 3:47pm |
You might need to double check… had that sheet for years 🤣 2011 Range Rover Vogue SE 4.4 TDV8
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
I've replaced loads now - really common for the low ranges to experience coil rub. They're XQM500170. They're about £50 each from main dealer. I'm aware of only one retrofit part which is the GAS PS3M62 PRO SPL. You'll need to get them imported from Norway however. They're about €100 for a pair, plus shipping, plus VAT. They are apparently significantly better quality than the Harmon Kardon speakers. You can actually replace these speakers without needing to remove the whole door card. Just remove the door card screws and pop off the lower trim clips and flex out the door card a bit and there's enough space to fit a small T20 Screwdriver inside to swap the speakers over. Takes about 5 minutes per door. There's 5 screws and 1 multiplug on the side of the speaker. 2015 Range Rover Autobiography 4.4 SDV8 |
5th Aug 2022 12:59am |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 |
Thank you very much guys ,going to order the genuine ones today. Mercedes AMG w207
5th Aug 2022 11:17am |
Sorry, a slight correction to my previous advice. XQM500170 was superceded by XQM500420 (I just found the part box in the garage and i have a brand new speaker I was unaware I had).
7th Aug 2022 10:49pm |
Thank you Gary your correct, new part numbers. Mercedes AMG w207
11th Aug 2022 8:36am |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 |
Came across this thread whilst looking for info and thought I'd link it to the thread I posted a while back, on replacing this speaker with another option: https://www.fullfatrr.com/forum/topic57819.html
15th Feb 2023 11:07am |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 103 |
Hi, trying not to hijack this thread, but has anyone the spec and part numbers of the HD set up? I can’t find any information anywhere. 2012 L322 Westminster. |
15th Feb 2023 1:52pm |
This thread has a full breakdown of the differences between the Logic 7 and Logic 7 HD: https://www.fullfatrr.com/forum/topic43436...logic+7+hd |
15th Feb 2023 3:30pm |
Thanks. Just what I need |
15th Feb 2023 8:09pm |
