Home > Maintenance & Mods (L322) > Upper tailgate question
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi chaps. Wondering if anyone can advise, I have a 2010 vogue se and it has the common rust along the bottom edge of the upper tailgate. It’s maybe a bit to far gone to repair so I’ve been looking for a replacement. I’ve seen one but the part numbers are slightly different. According to the jlr parts website, the part number for my car should be BHA760090, but the part number for the one I’ve seen is BHA760010. Have anyone got any experience changing the tailgate that could help?
Thanks,
Lewis
Post #637123 17th Jul 2022 5:08pm
When I looked a while ago there are two fitted, pre 2007 and post 2007, and from what I found, both are interchangeable, the earlier pre Tata ones don't rust so much... Thumbs Up Pete
Post #637141 17th Jul 2022 6:07pm
Phoenix
I've just bought a 10MY upper tailgate for my 08MY, dimensionally the same, the only differences I can detect is the camera position on the spoiler and a different wiper motor - the metalwork is directly interchangeable so I can't see a different part number for a L322 not fitting...
The only corrosion I've found has been minor rust spots around the rubber seal mounting holes and the drains, all of which is easily treatable.
Post #637155 17th Jul 2022 8:01pm
That's a rare find, a 10MY with no rust, (maybe it was a replacement under the rust warranty) make sure you fill it up with some rust preventer, then do it again to make sure... Thumbs Up Pete
Post #637158 17th Jul 2022 8:06pm
Phoenix
It's already stripped and the (light) rust ground out, all the parts have a late '09 production date including the glass so it's probably the exception that breaks the rule! I've no history of the donor vehicle, so who knows?
Post #637165 17th Jul 2022 8:47pm
Thumbs Up Thumbs Up Pete
Post #637168 17th Jul 2022 9:33pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Interesting replies.
I replaced my 2010 upper tail gate with a pre 2007 one and now the rear view camera does not give as good a view as before. I have been advised there is no adjustment on the camera, so it seems that the difference in part numbers might be because the camera fitting is different?
Other than the sightly reduced vision from the camera the replacement tailgate is fine. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #637650 23rd Jul 2022 4:57pm
G3BML
Did you have to change the wiper motor ?
Post #637654 23rd Jul 2022 5:21pm
Phoenix
The camera is mounted on the spoiler, the 10MY camera is in a different position on the spoiler and have a slightly different field of view and focal point due to the repositioning. The spoiler positioning on the tailgate and alignment with the 'D' pillars is dimensionally the same.
Post #637670 23rd Jul 2022 8:10pm
Phoenix
Yes, the wiper motors are different electrically - physically the same dimensions though.
Post #637671 23rd Jul 2022 8:11pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
i must be lucky when i first bought my 2010 back in 2014 my first job was to spray inside the upper tailgate with cavity wax its still rust free
Post #637692 24th Jul 2022 7:10am
And that would have cost JLR about 2 1/2pence to do when they made them...
If anyone is interested a new top tailgate is over £1000.... Shocked Pete
Post #637698 24th Jul 2022 8:56am
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
It is indeed - well over in fact.
Have just had mine done. The replacement panel alone was £1400 plus VAT.
Painting and other labour another £950 inc.
Chap did a lovely job mind. 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #638005 27th Jul 2022 10:10pm
The earlyest tailgate from 02-06 is made from the best (BMW) steel... Ford ownership 06-09 saw them get thinner, lighter and rust more... 09-12 saw TATA take over and use wafer thin steel that rusts even quicker!
Hope that helps Thumbs Up
Post #638022 28th Jul 2022 12:22am
Oh Triffic.
Doesn't bode well for my replacement then. 2011 L322 TDV8 A/b Orkney Grey
Post #638025 28th Jul 2022 6:05am
