Buy a spray can of cavity wax with a probe extension, park the fatty on a slight side slope, open the tailgate, put rags below the drain holes, squirt wax into the holes on the high side until it comes out of the drain holes further down, repeat until you have made a nice mess... Then open the lower tailgate, shut the top tailgate and repeat the process, this makes sure as much inside is covered as possible... Then turn the fatty round and do it again...
If you are going to keep it, do the rear arches and rear sill area as a minimum... Pete
