Home > Maintenance & Mods (L322) > Steering rack leaking |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
If it's like a brake banjo bolt try tightening it up first. |
17th Jul 2022 1:56pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
They do come loose, mine leaked from one of those.
17th Jul 2022 2:10pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Thanks both. Got it in the air and got under and it was loose so managed to get a ratchet spanner on and tightened it up. The fluid reservoir was nearly empty but had some fluid and have topped it up. Tried to bleed it but still a bit of a whine from the pump but will try a more thorough bleed and hope the pump hasn't been run dry too long and it's broke. The whine did considerably reduce so suspect a little bit of air still on there.
17th Jul 2022 4:02pm |
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 26 |
Hi there,
14th Mar 2023 10:43pm |
….and which screw needs to be tightened exactly? |
14th Mar 2023 10:44pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
If it is a banjo bolt that is the source of the leak, and the bolt is not loose, then the bolt may require new sealing washers, generally a copper sealing washer or a dowty seal ( metal washer with a rubber seal )
15th Mar 2023 12:14am |
It does, thanks! |
15th Mar 2023 7:09am |
On mine I could get under there on drive up ramps and I got someone to carefully turn the wheel and could see the fluid coming out. There are two bolts next to each other with lines coming out. I needed to use a wobble head ratchet spanner and was able to get it on and tighten the leaking one up and so far so good since then. I topped up the fluid and turned the wheel full lock a few times to expel any air and that was it.
15th Mar 2023 7:19am |
Will have a look, thanks for the heads up |
15th Mar 2023 8:20am |
Any of you guys happen to know the exact ZF part number for the steering rack?
15th Mar 2023 10:09am |
