![]() | Home > Maintenance & Mods (L322) > Steering rack leaking |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
If it's like a brake banjo bolt try tightening it up first. |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
They do come loose, mine leaked from one of those.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Thanks both. Got it in the air and got under and it was loose so managed to get a ratchet spanner on and tightened it up. The fluid reservoir was nearly empty but had some fluid and have topped it up. Tried to bleed it but still a bit of a whine from the pump but will try a more thorough bleed and hope the pump hasn't been run dry too long and it's broke. The whine did considerably reduce so suspect a little bit of air still on there.
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 33 ![]() ![]() ![]() |
Hi there,
….and which screw needs to be tightened exactly? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
If it is a banjo bolt that is the source of the leak, and the bolt is not loose, then the bolt may require new sealing washers, generally a copper sealing washer or a dowty seal ( metal washer with a rubber seal )
It does, thanks! |
On mine I could get under there on drive up ramps and I got someone to carefully turn the wheel and could see the fluid coming out. There are two bolts next to each other with lines coming out. I needed to use a wobble head ratchet spanner and was able to get it on and tighten the leaking one up and so far so good since then. I topped up the fluid and turned the wheel full lock a few times to expel any air and that was it.
Will have a look, thanks for the heads up |
Any of you guys happen to know the exact ZF part number for the steering rack?
