Home > In Car Electronics (L405) > Telematics battery
Dem75
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
Telematics battery
Hi. I’m getting SOS Limited availability pop up on my dash. Believe it’s likely to be a telematics battery. Anyone know where I should be looking please? Cheers
Post #636048 4th Jul 2022 4:57pm
Phoenix
It's mounted in the module itself which is under the drivers side dash, between the steering column and the 'A' pillar, quite a common occurrence at one time, just be careful to pull the connector, not the wires when removing the battery. IIRC it's under a plastic cover so not immediately obvious.
Edited to correct location
Post #636051 4th Jul 2022 5:32pm
