![]() | Home > In Car Electronics (L405) > Telematics battery |
It's mounted in the module itself which is under the drivers side dash, between the steering column and the 'A' pillar, quite a common occurrence at one time, just be careful to pull the connector, not the wires when removing the battery. IIRC it's under a plastic cover so not immediately obvious.
