Home > Maintenance & Mods (L405) > Exhaust Sensor - Or at least the bit the sensor screws into! |
SteveA Member Since: 14 May 2022 Location: Lancashire Posts: 14 |
Help needed - possibly from someone in the Lancashire area (Blackburn, Preston, Burnley, etc..)?
29th Jun 2022 3:34pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
29th Jun 2022 3:44pm |
Thanks dingg1. |
29th Jun 2022 3:57pm |
Thanks dingg1. I wonder if that will do it? It's the wrong thread / size but I'll message the seller to see if he can help. |
29th Jun 2022 3:58pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
29th Jun 2022 4:12pm |
Thanks Mike,
29th Jun 2022 4:41pm |
Oggy - sometimes the simplest ideas are the best! Iām not sure if the sensor needs to seal against something? |
29th Jun 2022 7:09pm |
29th Jun 2022 7:13pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi it looks like fig 3 is shorter than fig 4 i would measure the size of the offset i would say that it makes the sensor sit in the middle of the exhaust . if it needs a seal and is not tapered fit . you could use a dowty washer for the seal . i would weld the 12mm nut on to a say 14mm washer first so you get a good seal around the hex nut then it makes it a lot better to weld the washer on to the exhaust pipe with the mig welder new vehicle purchase
29th Jun 2022 7:47pm |
I'm loving the creative approach! Thanks. The mechanic isn't back until Monday but I can check the measurements then (when it's back on the ramp) and discuss whether this is feasible. I'll let you know. Thanks again! |
29th Jun 2022 8:06pm |
Drew a blank with this - the eBay seller has replied and said they don't manufacture them in the size I need. Thanks again. Great suggestion. |
29th Jun 2022 8:08pm |
a nut is cheaper try this link ebay item number eBay Item No. 275157999088 not cheap new vehicle purchase
29th Jun 2022 8:21pm |
Thanks oggy - well found! š. Will try the nut and washer route first though š |
29th Jun 2022 8:25pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
If he has a welder why not weld a nut to what's left of the original sensor, the heat usually breaks the seal and you can unscrew it with the nut you welded on... done it loads of time to all sorts and it usually works... Pete
29th Jun 2022 10:29pm |
