Home > Maintenance & Mods (L405) > Exhaust Sensor - Or at least the bit the sensor screws into!
SteveA
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Help needed - possibly from someone in the Lancashire area (Blackburn, Preston, Burnley, etc..)?
My local specialist has been trying to resolve a "DPF full" message and has found (amongst other things) a faulty sensor (Bank 1 Sensor 2).
Unfortunately, whilst removing the sensor, the sensor "bolt head" has snapped off, leaving the sensor body in situ in the exhaust. These things happen so I'm happy to accept it and try and find a resolution.
One idea he has had - is to drill another hole in the exhaust (within a couple of inches of the existing broken, redundant and irremovable sensor) and weld in a replacement "female adapter" that will take the new sensor. The issue is finding a "female adapter" that we can weld in.
So - to the "ask". Does anyone locally (East Lancs) have an old L322 exhaust lying around that I could take a section from to include the "female" adapter?
The sensor is on the exhaust Y section where the 2 downpipes come together on the driver's side. I "think" the adapter / sensor thread is M12 with a 1.25 pitch.
I'm not entirely sure if its relevant but my car is a 2011 4.4TDV8.
Failing that, any other ideas would be very gratefully received!
Thanks!
Post #635720 29th Jun 2022 3:34pm
dingg1
https://www.ebay.co.uk/itm/284487118312
Post #635721 29th Jun 2022 3:44pm
SteveA
Thanks dingg1.
Post #635722 29th Jun 2022 3:57pm
SteveA
Thanks dingg1. I wonder if that will do it? It's the wrong thread / size but I'll message the seller to see if he can help. Thumbs Up
Post #635723 29th Jun 2022 3:58pm
Baltic Blue
Is drilling it out and getting either a stud extractor or a suitable thread tap not possible ??
Post #635725 29th Jun 2022 4:12pm
SteveA
Thanks Mike,
The diagram is really useful - I hadn't fully understood the position of the sensor. Something tells me the actual position of this one makes it difficult to access to drill it out / re-tap it - but I'll double check. Cheers!
Post #635727 29th Jun 2022 4:41pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
if it is 12 mm thread can you not weld a nut on new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #635737 29th Jun 2022 6:49pm
SteveA
Oggy - sometimes the simplest ideas are the best! Iā€™m not sure if the sensor needs to seal against something?
Post #635738 29th Jun 2022 7:09pm
SteveA
Post #635739 29th Jun 2022 7:13pm
oggy
hi it looks like fig 3 is shorter than fig 4 i would measure the size of the offset i would say that it makes the sensor sit in the middle of the exhaust . if it needs a seal and is not tapered fit . you could use a dowty washer for the seal . i would weld the 12mm nut on to a say 14mm washer first so you get a good seal around the hex nut then it makes it a lot better to weld the washer on to the exhaust pipe with the mig welder new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #635742 29th Jun 2022 7:47pm
SteveA
I'm loving the creative approach! Thanks. The mechanic isn't back until Monday but I can check the measurements then (when it's back on the ramp) and discuss whether this is feasible. I'll let you know. Thanks again!
Post #635744 29th Jun 2022 8:06pm
SteveA
Drew a blank with this - the eBay seller has replied and said they don't manufacture them in the size I need. Thanks again. Great suggestion.
Post #635745 29th Jun 2022 8:08pm
oggy
a nut is cheaper try this link ebay item number eBay Item No. 275157999088 not cheap new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #635747 29th Jun 2022 8:21pm
SteveA
Thanks oggy - well found! šŸ‘. Will try the nut and washer route first though šŸ˜‚
Post #635748 29th Jun 2022 8:25pm
If he has a welder why not weld a nut to what's left of the original sensor, the heat usually breaks the seal and you can unscrew it with the nut you welded on... done it loads of time to all sorts and it usually works... Thumbs Up Pete
Post #635753 29th Jun 2022 10:29pm
