![]() | Home > Maintenance & Mods (L322) > USB |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
You need to make sure the USB stick you are using is formatted to FAT32…. Might do eFAT too, can’t remember. The Workshop manual in the Wiki should still be downloadable.
FAT or FAT32 then…
DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 42 ![]() ![]() ![]() |
No connection at all, no charging totally dead USB |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It won't charge anything. Its designed for memory sticks only really.
Yeah, it’s not meant to be charging anything, it’s for playing music on a USB stick.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
The connector on the back of my panel can become disconnected if the panel is unclipped, which it is prone to doing if not held in place while unplugging a stick, as the wiring is quite short. |
Thanks to everyone, finally got my car back after 2 months. Seems OK except for a few niggles. Fingers crossed |
Usb working fine, also got cigar lighters fixed with a fuse replacement |
Result. Glad you got it sorted.
