Home > Maintenance & Mods (L322) > USB
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
USB
Any ideas why the USB in the cubby box is completely dead? Anyone done an upgrade to the fitted entertainment system, if so what unit was used and was fitting relatively straight forward. Still looking for workshop manual for 2012 full fat with V8. Seems to be confusion if this is to be paid for, 100 days a member with a high level of posts etc etc. If available where is it, pretty please?
Thanks in advance, and info much appreciated.
Post #635503 26th Jun 2022 3:44pm
mjdronfield
You need to make sure the USB stick you are using is formatted to FAT32…. Might do eFAT too, can’t remember. The Workshop manual in the Wiki should still be downloadable.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #635508 26th Jun 2022 4:42pm
mjdronfield
FAT or FAT32 then…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #635509 26th Jun 2022 4:47pm
DEEBEE(060)
No connection at all, no charging totally dead USB
Post #635520 26th Jun 2022 6:38pm
garyRR
It won't charge anything. Its designed for memory sticks only really.
That's because I think the port is 0.25A so, is only 1 watt ‐ probably not enough for most modern rechargeable devices to even register a charge.
Just grab a 12V QuickCharge 3 adaptor from Amazon. Mine charges my phone just as quick as my fast charger at home. 2015 Range Rover Autobiography 4.4 SDV8
Post #635534 26th Jun 2022 7:46pm
mjdronfield
Yeah, it’s not meant to be charging anything, it’s for playing music on a USB stick.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #635537 26th Jun 2022 7:53pm
GraemeS
Australia
The connector on the back of my panel can become disconnected if the panel is unclipped, which it is prone to doing if not held in place while unplugging a stick, as the wiring is quite short.
Post #635549 26th Jun 2022 9:45pm
DEEBEE(060)
Thanks to everyone, finally got my car back after 2 months. Seems OK except for a few niggles. Fingers crossed
Post #637851 25th Jul 2022 10:44pm
DEEBEE(060)
Usb working fine, also got cigar lighters fixed with a fuse replacement
Post #638556 3rd Aug 2022 12:00am
mjdronfield
Result. Glad you got it sorted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #638565 3rd Aug 2022 8:11am
