![]() | Home > Technical (L322) > Pre-heat problem |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
I'm afraid that's not unusual mate. Mine does it.
Like this. |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 124 ![]() ![]() |
I'm assuming its behind the arch liner in the left wheel well? I'm going to do some preventative rust treatment in there at the weekend so I can take a look then and see where the smoke is coming from. 2nd hand heaters are going for £90, I dread to think how much a full OE unit is.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
The exhaust for the fuel burning heater is down near the mudflap. It’s normal to see something from there when the preheat is running, but as to how much and for how long I’m no expert….
Yes. you can get a refurbed one for about £100. |
I had the arch liner off, the exhaust from the heater wasn't plugged into the unit! I don't know how that would have happened as it was quite a struggle to get the exhaust back on. I've not had the chance to check it since but could that have created the smoke and the smell of diesel? There's not much to the exhaust, though there is some sort of small box on it? Anyway, I'll try it again on the next cold morning we get and see if that's fixed it. |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 89 ![]() ![]() ![]() |
I know nothing about these heaters and my 07 3.6tdv8 is, I think, not fitted with one. However, in a parrallel universe, my step son has recently fitted a diesel heater as part of a camper van conversion. Boy that thing makes some smoke for a while until its warmed up but thereafter there's virtually nothing visible from the exhaust.
Agreed, that should have resolved the issue…… onwards and upwards 🤣.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Fitted as standard on diesels. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
^ my 3.6 had one, was mostly broken most of the time…. There is nothing that can't be fixed with a hammer😜😜
To close this out, I tried the pre-heater again today and after having relocated the exhaust, everything is now working as it should. No more smoke or dodgy smells. Its nice to have such a simple fix! |
