Home > Maintenance & Mods (L322) > I have rust
Sandyt
I have rust
Well I am just amazed I have a bit of rust on the sills inside both rear doors my guess about 2 grands worth but hey ho its done well to get this far
Post #635306 23rd Jun 2022 8:14pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
same here need to get mine sorted........ Crying or Very sad
Post #635311 23rd Jun 2022 8:48pm
Flashman
You can get replacement body panels for the repair on eBay for about £60 per side. Depending on if the rust has affected the structural frame you might need some welding to reinforce things. From what I have read the work to do both side would be in the region of £600-£1k depending on the extent of rust.
It seems to be affecting all the L322s and is a case of when not if. You can lessen the risk by clearing out the channels behind the wheel arch as mud and water get stuck behind them, leading to the issue. Tom
Current Drive
Previous Drives
Post #635372 24th Jun 2022 3:35pm
Rjh112
Mines going in on Monday for rear arches where doors close and sills, £2600 all in, it’s a common area for rot.
Post #635460 25th Jun 2022 8:38pm
Sandyt
Its going in when I get back from France its not too bad but will have it all cut out anyway as no good doing something by half.
I mean its only on 215k and fifteen years :}
Post #635481 26th Jun 2022 7:33am
