You can get replacement body panels for the repair on eBay for about £60 per side. Depending on if the rust has affected the structural frame you might need some welding to reinforce things. From what I have read the work to do both side would be in the region of £600-£1k depending on the extent of rust.
It seems to be affecting all the L322s and is a case of when not if. You can lessen the risk by clearing out the channels behind the wheel arch as mud and water get stuck behind them, leading to the issue. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
