Home > Maintenance & Mods (L322) > 150K miles coming up soon |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 119 |
All,
17th Jun 2022 2:19pm |
Thanks, clearly don’t want to go silly, as I say, “ain’t broke” but the bearings at the front need doing, so.
17th Jun 2022 4:03pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Front aux belts, bearings and tensioner are a normal replacement / service item at higher miles. Don't delay if they are noisy. 2012 TDV8 Vogue (L322) |
17th Jun 2022 4:11pm |
agreed, as they are going in there, that’s why I want some advice on what else to do while is apart. Check out my YouTube channel
17th Jun 2022 4:18pm |
I'd defo do the alternator then at that mileage. Had the water pump done on mine as it was leaking but not sure if it's a common fail but they are not too expensive. 2012 TDV8 Vogue (L322) |
17th Jun 2022 4:21pm |
Thanks, thinking the water pump as a matter of course, alternator, probably pushing it now at 150k Check out my YouTube channel
17th Jun 2022 4:33pm |
Kicking myself for not having mine done at the same time as belts and water pump…. 2012 TDV8 Vogue (L322) |
17th Jun 2022 5:51pm |
Good call, thanks Check out my YouTube channel
18th Jun 2022 7:35am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1222 |
I've just done everything on the front of my engine mate, all pulleys, tensioner, water pump and while I was there the alternator as well.
18th Jun 2022 8:25am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
Starter motor maybe too. They get a lot of abuse turning a 4.4L engine.
18th Jun 2022 9:27am |
Gearbox has been flushed and new sump and filter. Agreed genuine all the way 👍🏻 Check out my YouTube channel
18th Jun 2022 10:39am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Front seat filters...? Pete
18th Jun 2022 10:57am |
Already replaced when I changed the fan motor over 👍🏻 Check out my YouTube channel
18th Jun 2022 11:00am |
Vent on air suspension pump and change/dry the dryer medium...? Pete
18th Jun 2022 11:03am |
