Home > My Range Rover > Finally - got my new Vogue |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Congratulations, welcome to the wonderful world of Range Rover ownership, not without it's challenges, but well worth it!
16th Jun 2011 8:26pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
I'd say it looks good, but you've committed a crime in not posting a picture
16th Jun 2011 8:32pm |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
I'm definitely in the right place as I've found the fix for 2 of my 3 problems already.
16th Jun 2011 8:38pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Stone chips? Have a look at our group buy might be well worth it!
16th Jun 2011 9:44pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7939 |
That's because they are nearly impossible to find anywhere else ! |
16th Jun 2011 9:54pm |
On a long run the temperature gauge will usually be in the middle but every now and again it will climb up to the 3/4 mark before dropping quickly back down to the middle. It's the sort of thing I might expect if stationary and the fans kicking in but not at a steady 70. Forum says - flush the coolant and refill. The middle phone light keeps flashing but apparently that's because the sim isn't in. I don't actually have a phone fitted so not entirely sure how to fix that one. Final problem is that the radio and TV is very echoey. No idea what's going on there. |
17th Jun 2011 7:56am |
Oops. |
17th Jun 2011 7:57am |
Have you got the TD6 or V8? |
17th Jun 2011 8:22am |
A nice thirsty V8. |
17th Jun 2011 9:49am |
Good choice! The temp problem could be a sticking stat or an airlock. Use the hidden menu to see what temp your actually running as the gauge is notoriously $hit! |
17th Jun 2011 10:37am |
I've checked for airlocks and all seems ok.
17th Jun 2011 11:51am |
That's probably just the current DSP settings. Access from the main menu. |
17th Jun 2011 12:12pm |
Thanks! I'd found the bass/treble but that didn't help. Must RTFM more carefully |
17th Jun 2011 4:50pm |
There are presets in the DSP so clasical, theatre etc. You may have one of them selected. Where and which menu there in I can't remember.
17th Jun 2011 6:20pm |
