Home > General (L405) > Difference between a SE and a Autobiography L405 2013
Tiny Timmy
Whats the difference between them?? I cant seem to find out anywhere................TT
Post #633980 8th Jun 2022 5:40am
As I understand it the SE is to a standard spec with a few options available to add
Autobiography is totally customable, you can add, and subtract almost anything... they tend to be better spec than an SE but it depends what the first owner wanted...
My 5.0 SC Autobiography (L322) had loads of extras, far more than an SE but it didn't have a venture cam as the original owner didn't want one....!! Pete
Post #634007 8th Jun 2022 10:56am
Can be tough - they are basically kind of options packages and most things can be spec'd individually, so any given car may have more than you might think.
IIRC the AB has more adjustable & massage front seats. More leather bits of trim. Maybe a bit of extended wood. Probably park heat as standard. Not sure whether the AB had a leather headlining ?
Really its a case of figuring out which options you want & ensuring any car you find has them.
For my wife, cooled front seats was a requirement, for me, a minimum of 825w music system - so my search was VSE or AB - though both were possible on a Vogue, it was just easier to search that way.
Post #634008 8th Jun 2022 10:57am
Tiny Timmy
Thanks for your help.
Its just a bit of a mine field trying to find it all in the descriptions.
Ill keep looking, I was hoping there was a list Big Cry
Post #634010 8th Jun 2022 11:13am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
I think they are both customisable, the basic difference was the standard trim in an Autobiography, this has full leather dash, full leather door cards, full leather roof lining etc where as the Vogue spec has part leather dash, door cards and I don't think it came with a leather roof lining.
There may have been some other minor things as standard on the Autobiography but most items were options on both cars.
Im sure there is a spec comparing both Vogue, Vogue SE and Autobiography on here somewhere. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #634016 8th Jun 2022 11:32am
I'm sure there will be a list somewhere in a 2013 sales brochure - but most things could be spec'd at a cost if the original owner wanted them - so it will just show the base accessory level for the model.
If you're buying used, then there are so many other factors to consider - interior & exterior colour, tow bar, steps, wheels etc and that's before mileage, condition, history etc.
Post #634017 8th Jun 2022 11:36am
I found this one, but it's the US version - will likely give you a good idea of what is only on the AB though - https://www.auto-brochures.com/makes/landr...r_2014.pdf
There are definite differences to the UK though, for example the 1700w audio was an option here on all models & 825w standard on VSE & AB - looks like the US had 1700w standard on the AB
Post #634019 8th Jun 2022 11:44am
Tiny Timmy
Thanks Alistair, give me something to look at , quite a bit of info there Thumbs Up
Post #634023 8th Jun 2022 11:53am
