![]() | Home > General (L405) > Difference between a SE and a Autobiography L405 2013 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8557 ![]() ![]() ![]() |
As I understand it the SE is to a standard spec with a few options available to add
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
Can be tough - they are basically kind of options packages and most things can be spec'd individually, so any given car may have more than you might think.
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 202 ![]() ![]() |
Thanks for your help.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
I think they are both customisable, the basic difference was the standard trim in an Autobiography, this has full leather dash, full leather door cards, full leather roof lining etc where as the Vogue spec has part leather dash, door cards and I don't think it came with a leather roof lining.
I'm sure there will be a list somewhere in a 2013 sales brochure - but most things could be spec'd at a cost if the original owner wanted them - so it will just show the base accessory level for the model.
I found this one, but it's the US version - will likely give you a good idea of what is only on the AB though - https://www.auto-brochures.com/makes/landr...r_2014.pdf
Thanks Alistair, give me something to look at , quite a bit of info there |
