Home > Technical (L322) > Difficulty fitting new Brembo front pads to L322 TD6 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Remote diagnosis is never easy, but......Wracking what brain cells I have left.....
2nd Jun 2022 10:57pm |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
Thanks for your reply, yes I did use a G clamp that was suitable for the job, parts definitely the right ones
3rd Jun 2022 10:51pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
The state of that piston l would be changing the calliper before it causes you trouble. Don’t ask me how l know. |
4th Jun 2022 10:28am |
The calipers could also be over hauled using new pistons / seals.
4th Jun 2022 12:04pm |
In the past ive sent motorbike calipers away for overhaul at a specialist due to leaky seals, and on other motors ended up swapping calipers if either A bleed nipple is ceased or B handbrake sticky. I hadnt seen this much surface rust on a piston before upon closer inspection as recommended. I guess if the piston pushed back originally all the way I wouldnt have even wrote this post .
4th Jun 2022 2:23pm |
