Home > Technical (L322) > Difficulty fitting new Brembo front pads to L322 TD6
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
This Jubilee bank holiday see's me finally swapping out my noisy power steering pump & replacement from disc and pads.
PAS Pump all swapped and bled up, jobs a gooden.
Then we move onto the brakes.......old pads and discs off, new discs on, pushed back caliper pistons as far back as they would go with a G clamp and block of wood (with the brake fluid res cap undone) + I cleaned up the calipers a bit.
I then inserted the new Brembo pads into the caliper carriers, I then went to fit the caliper over new pads but I was not able to fit the caliper over the new Brembo pads.
I then removed the caliper again and was able to push the caliper pistons back another small amount using the G clamp once again, but still I was not able to get the caliper over the new Brembo pads.
As the original pads that were in there had years of life left in them, what I ended up doing to finish one side was to use 1 old pad (Apec) with the sensor on and 1x new Brembo pad on the outer edge.
The part number I ordered was Brake Pad Set - SFC500080BREMBO - Brembo from "Rimmer Brothers"
I know they fit, but its almost like the pads got 5mm too much meat on it.
I have tried to get the piston back further but it will not go back any further
Any ideas ? Very Happy Current Fleet
FF L322 2.9TD6 SE
BMW e46 330ci Msport
Skoda Superb TDI Mk2, stage 1
Audi A3 8P 2.0 T 4x4, stage 2
Yamaha R6 13S
Triumph Thruxton R
Sold, but not forgotten
WJ Jeep Grand Cherokee V8
Post #633562 2nd Jun 2022 9:44pm
Merchy
Remote diagnosis is never easy, but......Wracking what brain cells I have left.....
Compatibility issues between parts?
Brake carrier not scrupulously cleaned up, deposits left? Rust scale deposits can be very thick. Use of hammer and chisel is not uncommon to remove deposits that look like metal.
Stainless spring plates incorrectly fitted ?
Incorrect parts in box by accident from maker / factory?
Not the right pads? - 5mm does seem excessive.
Wrong parts for model / year? - Do not know the part numbers myself.
May sound daft, but please do not take offence - G clamp at the end of it's travel / thread damaged, will not go further?
I know what will happen next, the next 'postee' will post the obvious answer that I missed Whistle Rolling with laughter
When you solve the problem, please post your answer / solution Thumbs Up
Post #633578 2nd Jun 2022 11:57pm
mazza7282
Thanks for your reply, yes I did use a G clamp that was suitable for the job, parts definitely the right ones
Merchy ! - you have hit the nail on the head in fact.
Even though I cleaned up the caliper carrier, it was the outer piston itself that was covered in Censored and rust (Offside)
Before I tackled the rusty offside caliper again, I decided to take a stab at the nearside to see what that side was like. Turns out its had a new caliper at some point on this side, as we can see by the distinct lack of rust inside the chamber there.
Quick brush up with a soft brush and this piston pushed back in with no problems at all, the replacement Brembo pads went straight in as I was able to push the piston all the way.
Returning to the offside rusty caliper, I decided to pop the piston out at much as I dare to perform further inspection.
As we can see it the surface rust around the end of the piston is what was stopping it being pushed back into the caliper, I have also noticed 2 small holes on the dust cover. I just left it to be honest (could have popped a but of sealant around it), but by the time the piston gets pushed back into the caliper again it all folded in and disappeared anyway so....
After taking a dremel at it, cleaned it up and coated it the piston in the smallest amount of grease known to man, the piston pushed back in all the way (the missing 5 mm!) Rolling with laughter
Added the lonely brembo pad & old sensor back as it hasn't worn out and all good !!!
Lesson learnt really regarding rust around the piston, I didn't even take much notice originally thanks for your help. Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #633654 3rd Jun 2022 11:51pm
The state of that piston l would be changing the calliper before it causes you trouble. Don’t ask me how l know. Thumbs Up Very Happy
Post #633674 4th Jun 2022 11:28am
Merchy
The calipers could also be over hauled using new pistons / seals. Thumbs Up
When metal oxide ( Rust ) layers build up, there is quite an expansion ration from metal to rust, if memory serves me correctly with basic mild steel the expansion ratio can be up to 6 to 1, so lose 1mm metal and you could gain 6mm of rust.
Post #633679 4th Jun 2022 1:04pm
mazza7282
In the past ive sent motorbike calipers away for overhaul at a specialist due to leaky seals, and on other motors ended up swapping calipers if either A bleed nipple is ceased or B handbrake sticky. I hadnt seen this much surface rust on a piston before upon closer inspection as recommended. I guess if the piston pushed back originally all the way I wouldnt have even wrote this post Smile.
Ive also got a 200.000 touran that I wasnt able to successfully undo the bleed nipples on both front calipers due to rust but the pistons didnt look anything like the ones on this range rover.
Braking performance is still as good as it was before on this old girl, and now that shuddery steering wheel is a thing of the past when breaking.
Also ended up tightening the handbrake up a bit as we were almost 9 clicks up rather than the 7 as the manual stipulates (which even then is quite high)
Also had my MOT guy say yr before last that it was advisory, showed him the workshop manual stating 7 clicks. Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #633686 4th Jun 2022 3:23pm
