Home > Technical (L405) > Fault code. Permanent DTC P040D
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Just back from service, all ok. My trusted Indy says the fault code, Permanent DTC P040D. EGR temperature sensor A high circuit, is showing, but does not throw up any dashboard warnings. He says everything is ok, so don’t worry about it. Any thoughts please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #633362 31st May 2022 3:20pm
GrandadRob
Sorry Guys, did a search and found out what it is. Causing no issues, if it ain't broke, don't fix it. 2013 SDV8 4.4 SE Luxor.
Post #633375 31st May 2022 5:08pm
Do you have a garage at home? Reverse the car in and leave it running, then walk around the back and smell how strong the diesel fumes are... If it stinks like an old ice cream van then go and have the probe changed...
Mine failed and in basic terms, told the ECU the engine was cold! The engine ECU then increases the fuel rate to warm the engine up! All it does then is fill the DPF with unburnt fuel! Shocked
Other members have found the probe has failed in a way that doesn't over fuel the car... I'm skeptical the failure must cause some amount of under/over-fueling, however small? And that is a fault that in my book needs to be fixed... Thumbs Up
Post #633417 31st May 2022 10:39pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I concur with your thoughts on that, the car will smell less when working properly.
Post #633420 1st Jun 2022 6:56am
GrandadRob
Would this not trigger an emissions test failure. It passed its MOT yesterday. 2013 SDV8 4.4 SE Luxor.
Post #633422 1st Jun 2022 6:57am
Tinman
Not really as it's a temperature probe, I think It's burnt emissions that they are looking for?
Post #633426 1st Jun 2022 7:07am
JCW
But if it’s consequentially over-fuelling / potentially clogging the DPF in some instances, I’d be surprised if the MOT emissions test didn’t pick this up?
It’s also odd to me it doesn’t trigger an EML fault similarly?
NB I also have this error code logged on my L405 but haven’t noticed any overly heavy fumes / smell.
Post #633427 1st Jun 2022 7:11am
Ok, my thoughts for what they are worth are this… If you have a scale from 1 - 10 and your probe fails in position 1 - 3 for example you may have excessive lean running issues when your engine is cold? And on that same scale 7 - 10 may overfuel? Causing DPF clogging issues?
So, if your car fails on 5 in the above scale and causes you no noticeable issues? Your temperature probe is still not operating within the parameters to heat or cool the engine correctly! Now if you don’t mind risk then this might not worry you? I would prefer to limit the risk and limit the ongoing risk of the probe failing more or in a worse state!?!
There may also be another sliding scale of the degree of failure of the probe? Meaning, if your probe only delivers 80% of its information and in 4 weeks that will decrease to 60% for example? How long before your EML light is illuminated and or your in limp mode?
I like to work on proactive problem solving and preventative maintenance. So I always try to fix these issues as early as I can… 👍
Post #633451 1st Jun 2022 10:35am
And to add to the above, the cost of a replacement probe & fitting will cost you X at the moment… The cost of the probe PLUS a DPF gets significantly HUGE, very quickly…
Food for thought 👍
Post #633458 1st Jun 2022 11:40am
DrRob
It's an easy decision in my book.
Get it changed. It's faulty.
Job done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633459 1st Jun 2022 11:45am
JCW
Yep I’d agree - regardless of the fail state / lack of EML, a fault is a fault & the sensor needs changing Thumbs Up
Post #633464 1st Jun 2022 12:41pm
GrandadRob
There are other larger threads on this subject. On this forum. 2013 SDV8 4.4 SE Luxor.
Post #633477 1st Jun 2022 4:28pm
DrRob
Yes, 13 pages of debate Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633482 1st Jun 2022 4:47pm
