![]() | Home > Technical (L405) > Fault code. Permanent DTC P040D |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 227 ![]() ![]() ![]() |
Sorry Guys, did a search and found out what it is. Causing no issues, if it ain't broke, don't fix it. 2013 SDV8 4.4 SE Luxor.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Do you have a garage at home? Reverse the car in and leave it running, then walk around the back and smell how strong the diesel fumes are... If it stinks like an old ice cream van then go and have the probe changed...
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1207 ![]() ![]() ![]() |
I concur with your thoughts on that, the car will smell less when working properly. |
Would this not trigger an emissions test failure. It passed its MOT yesterday. 2013 SDV8 4.4 SE Luxor.
Not really as it's a temperature probe, I think It's burnt emissions that they are looking for? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
But if it’s consequentially over-fuelling / potentially clogging the DPF in some instances, I’d be surprised if the MOT emissions test didn’t pick this up?
Ok, my thoughts for what they are worth are this… If you have a scale from 1 - 10 and your probe fails in position 1 - 3 for example you may have excessive lean running issues when your engine is cold? And on that same scale 7 - 10 may overfuel? Causing DPF clogging issues?
And to add to the above, the cost of a replacement probe & fitting will cost you X at the moment… The cost of the probe PLUS a DPF gets significantly HUGE, very quickly…
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
It's an easy decision in my book.
Yep I’d agree - regardless of the fail state / lack of EML, a fault is a fault & the sensor needs changing |
There are other larger threads on this subject. On this forum. 2013 SDV8 4.4 SE Luxor.
Yes, 13 pages of debate |
