Home > Technical (L322) > FBH Parking heater as auxiliary or engine pre-heater? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7819 |
I’ve not heard of that before. I know it comes on once you have started the engine to help it warm up in cold weather.
31st May 2022 1:28pm |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 |
Doesn't the FBH heat the cabin by heating the coolant & thus the heater matrix?
31st May 2022 5:41pm |
Yeah, but I’m imagining the question is for the engine only. I can’t imagine the L320 having a different system to the L322 though. It can heat the engine coolant with the engine off, but only when it’s heating the interior also.
31st May 2022 6:05pm |
The early L319 / L320 have different plumbing, the FBH was only intended as a boost heater when the engine was running and the exterior temperature below 4 deg. C., consequently, if a remote control or timer was added, due to there being no coolant valves to control the circulation dependent on the running / parked state of the vehicle, the whole coolant circuit was heated, thereby pre-heating the engine. L322 was specifically designed to have park heating (and has the valves and control logic to allow it) as well as boost heating for the engine. Later L319 / L320 have the option in some markets for park heating with or without remote control, these also have the correct plumbing so that all the heat is directed into the cabin and not 'wasted' on the engine, I suppose you could bypass the valveset so that the engine is pre-warmed (heated is a bit of a stretch) if you really wanted to. |
31st May 2022 6:43pm |
Alas last winter here was the mildest I've known so I only used the FBH / remote on mine once (apart from making sure it worked).
31st May 2022 7:07pm |
The FBH (Thermo Top C in L322, Thermo Top V in early L319 / L320) has a circulation pump, if this is not detected as running in park heating or boost heating, the FBH will shut down,. |
31st May 2022 7:18pm |
